Xperia S galery bug
Andre_antunes
Xperia S galery bug
Some strange pictures appear in the gallery but I dont know how to delete them. Every time i try to delete them the application crashs and is closed 🙂
10 REPLIES 10
Not applicable
look like you phone is picking up some pictures from one of your apps,
i had this problem with fifa 12 on my phone, you need to locate where the pictures are from and add a file into the folder called .nomedia
this will tell your phone not to put any pictures in that folder into your gallery,
i.e if it was in bc news app, go to the sd card on your phone and locate the folder for the bbc app and add a new folder called .nomedia
this worked for me on football manager, fifa 12 and bbc sport app,
its just poor app building from the developers,
