I want to replace the antenna on experia go.
can i do that and ware can i find the gsm antenna on the phone
and ware can i buy new antenna.
Thanks for all help
Foppa
thanks for the reply. but I looked around inside the page and I can not find anything that is an antenna for Experia go. I would be grateful if you could link to exactly what I need. Sincerely, John
http://talk.sonymobile.com/t5/Xperia-go/Xperia-Go-Gps-antenna-location/td-p/301831
as for the parts just google it and look around
