- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi all.
I bought this new television today, and I love it so far, but the thing at the moment that is bothering me is the HDMI inputs don't switch automatically when turning each piece of equipment on. The Sky box is on HDMI1, a pc on HDMI 3 and an xbox360 on HDMI 4.
I've just got rid of an old bravia kdl-40u2000 and I had a 3 way switch plugged into the back of this due to this television only having 1 HDMI port. Now the new tv has 4, I thought this would be easy but no, I have to manually switch the AV input. Am I missing something very simple, or does this option just not exist.
Thanks in advance for your help
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thank you all for your help. Manual it is then.
Annoying really, when a small cheap HDMI splitter from Maplin can do it but an expensive TV cannot.
Oh well
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
As I said before, your tv CAN do HDMI switching . The problem lies with your connected equipment. They are are not sending any HDMI control signals to the tv.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well i just got home with this and very disappointed so far....
connecting a computer via hdmi and the audio is not getting through. Have restarted in various orders, played with the settings, but nothing. I have another bravia tv that is just 3 years old and that works fine, with the same computer. One of the reasons why i stuck with Sony.
any ideas? other than take it back ?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Are you sure that you audio is NOT disabled when HDMI cable is connected? Just double check anyhow - ensure there is no tick next to disable - Control Panel > Sound :
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi! I have same problem with hdmi autoswitching on my Sony KDL55W905A! And i believe, that the reason for that is my Sony tv! I had before Panasonic Plasma tv and there was no problems with hdmi autoswitching. The problem is with my Digibox, Handan 9901. My Sony Bluray is working ok (hdmi autosswitching) with my Sony tv, so it was also with my previous Panasonic Plasma!
