Bravia TV - 2 Screens
I just hooked up a new Sony Bravia 32 in Television and I keep getting alternating screens at top and bottom. I do not know if they are part of the TV set up or from the Cable Co. one is screen enhancer the other unknown.
2 REPLIES 2
Anonymous
Not applicable
Hi @farleytimj
This one is hard to give an answer to, are you able to post a photo of whats happening?  As well as the model number of the TV.  You might be in some sort of Picture-And-Picture mode (which is side by side), but never heard of Top and Bottom (except gaming).
Anonymous
Not applicable
Hi there
I have thought about your problem today, and if its still happening, you might have 3D mode set to Over-Under?  If so, ensure this is OFF.
