- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have a new Bravia. When i try to access the Web through the Applications Menu, Internet Browser it takes me to a "choose Country" page and after selecting UK, to the Sony UK Website.. I can't get further than this. Is there a way to access a web browser.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
problem solved by going to Options and selecting 'enter url' .. everything working fine now, though a lot slower than pc or laptop..
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Unfortunately I cannot give you full step by step instructions as I dont have a 2014 TV, but should be reasonably close.
- Load up the web browser as per the FAQ instructions : HERE
- Press the [Options] button on the remote control, and the following menu should appear:
- Scroll down to "URL Entry" on the menu and press [OK] on the remote control.
- Use the on-screen keyboard and type in the web address (ie http://www.google.co.uk)
- When done, highlight the [Enter] button on the on-screen keyboard, and press the [OK] button on the remote control.
Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
:smileyconfused:I also have same problem with my new sony bravia TV, (Sony web page preventing me for accessing the web browser) my tv model is KDL-26EX320, but when I choose 'Options' the 'Url' choice is not listed. Can anyone suggest an alternative solution?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
on the sony kdl bravia i cant access internet browser it come up as file not found with blank screen any help please
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
i go on to the app browser it comes up saying file not found
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have a Bravia TV (Sony Bravia KDL- 24EX320). I want to access the web. I go through the process and get the Google search page up by inserting the Google URL and achoieve the Google search page. However how do I then get into the Google search line in order to type in a search the internet.
Cheers DB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Thats the difficult part. You need to use your remote controls arrow buttons (up/down/left/right) to basically give focus or highlight the search text box. Once done, just click the OK button on the remote control and an on-screen keyboard will be displayed.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I can get the google search text box but when I highlight it and press OK, nothing happens. The on screen keyboard input box does not appear. Could it be that Google is the wrong search engine to use? DB
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Your model is a 2011 TV, I also have a 2011 TV, and google works just fine on the TV, so....
Try going to a website that has another text input box and test to see if the onscreen keyboard works. If it doesnt, I think a factory reset of the TV is required - as I vaguely remember that this resoved someone elses problem.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
