can you switch presence sensor off?
ronwalters
Are you able to switch presence sensor off so tv stays on if no one in actual room?
2 REPLIES 2
profile.country.en_GB.title
StartTheCar
Contributor
Hi
Yes, the options for this feature are usually found in the Eco section of the System settings.  If you can dig out the  model number for your Bravia, I should be able to be more specific.
Otherwise, hope this helps.
Lee
ronwalters
Thanks for response, Ron
