- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Hi
Thanks in advance for any replies.
I am trying to set up wireless connection on my bravia using the dongle UWA-BR100
When I do a scan I see my connection
I have tried with WPA settings no joy.
I tried with WEP as this is the setting which connects fine to my laptop.
However this comes up with 'The number of characters is invalid' even though I have entered correctly and with 26 characters.
UPDATE:
I changed the wireless to No Security and got a connection but obviously not ideal so my query still stands - many thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, I had the same problem with Orange Livebox. The Bravia would scan and find the Livebox but when I entered the WEP code it just returned to the same menu. I turned off security settings on the Livebox and the Bravia connected straight away, but not good with no security. I then reset the Livebox security and entered the WEP code in the Bravia's "MANUAL" settings it then connected with no problems. Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Are you able to connect without any security in place?
Thanks
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi thanks for sharing this info, I'm trying to do the same with the livebox but to a panasonic.
Can I ask how you turned off the security settings on the livebox please?
I see you entered a wep code( as I do if I let a guest use my livebox) but I don't have a box to do that on the panny
Any wisdom gratefully received!
