Not even rec'd yet (delivering tomorrow) but first question I have for you guys is can I connect a pair of external speakers to this set to enhance the stereo whilst playing my music DVD's via the HDMI connected Tosh VHS/DVD combi? thanks
If you have a hi-fi or surround sound amp with an optical audio input then you could output the sound from the tv using an optical cable.
According to the tech specs
http://support.sony-europe.com/techspecs/masterspecs/tech_specs.aspx?site=odw_en_GB&m=KDL-37EX503
the TV doesn't have stereo RCA or headphone outputs you could use with simple powered speakers.
