fault with 32ex703 tv screen
profile.country.en_GB.title
jimbob62football
bought a kdl 32ex703 tv over xmas, turned the set on for first time today, it appears to have a white glow in the bottom right corner, this can be seen on dark backgrounds and when you bring up the sky program list page, an ideas?
1 REPLY 1
antomki23
Hi. I have the same tv. Since you bought it, have you altered the picture settings, for example:- contrast, brightness, colour etc? If not, if you go into the picture settings menu, try reducing the 'led backlight' setting. They are often turned WAAAAY up to help the picture 'POP-out' at you in the shop.  Just a suggestion, but it sounds like the white glow that you are seeing could be that led back light. I hope it helps, its a fantastic picture once you've set the colour and things properly!  Cheers, Andrew.
