Updated firmware last year with no problems but recent update fails to be found by TV system . Same usb stick, formatted FAT32 ,firmware issue 1.741EA.....any ideas??
I believe that the problem is caused by the download renaming the file i.e. firmware(1).upd,this is caused if an existing update file is present in your "Download Folder" Delete all .upd firmware files then download the latest one . This has worked successfully for me.:smileyhappy:
Message was edited by: joleemi90
