Hi there
What model TV do you have?
As a suggestion:
If that works, repeat procedure and connect HDMI leads to the desired ports (probably original setup)
Also, you cannot roll-back firmware updates.
Hey there
Your not having much luck hey. What model Bluray player do you have?
A couple more suggestions :
If that fails, I guess we need to figure out if its a connection fault at the TV end or the bluray player end.
Hope that helps
