Help needed with Bravia NX813 set-up using a Blu-Ray source
profile.country.en_GB.title
Rockeyes
I have a Sony KDL-55NX813 and a Sony Blu-Ray BDV-E670, connected via HDMI.
How Can I adjust the screen settings (Brightness, contrast etc) on the TV with a Blu-Ray disc playing?
I cannot seem to access the TV screen setting menu without loosing the Blu-Ray. I’m trying to set up the TV using a THX optimizer on a Disc.
Thank you
4 REPLIES 4
profile.country.hr_HR.title
DamacizSi
I would use some settings on BDV-E670  connected to Bravia... check instruction manual
:slight_smile:
Rockeyes
Thank you for trying to help but there does not appear to be anyway to adjust the brightness, contrasts etc settings though the BDV-E670W screen settings. Surely there must be a way to adjust the settings whilst viewing a THX set up on a Blu-Ray disk.
Catmambo
Contributor
Have you tried pressing 'sync menu' when its playing - this gives you access to TV menu functionality I think?
Rockeyes
The Sync option has done it :slight_smile: but having problems getting back to the player. The THX option screen seems frozen. Looking to get this fixed before trying to sort out the lip sync problem :slight_frown:
