How do I reset my TV?
profile.country.ro_RO.title
ioanamaria61
I don't have sound to my new TV and I want to reset it .I followed the instructions and I couldn't reset it. Is something that I don't understand."While holding down on the remote control,press POWER on the TV.The TV will turn itself off than back on again(which did not)(no way) Release the arrow than" Were did I do wrong?
profile.country.en_GB.title
Catmambo
Contributor
There is also a factory reset option in the settings menu as well if you press home and then browse to the left hand column...
2 REPLIES 2
Catmambo
Contributor
profile.country.hr_HR.title
DamacizSi
Ok, Catmambo is right and I will just specified it
manu-settings-system settings-general set up-factory reset
If TV ever ask for code after reset, so You can always use 9999
Regards
Damac:smileyhappy:
