Hi
new purchase of KD49XF7002BU
when tv is switched on, it always defaults to digital input.
i always watch through sky box on input hdmi 1, but it always defaults back to digital even though the TV is switched off while watching input hdmi 1, it doesnt seem to remember this and i always have to change it on the inputs menu from digital to hdmi 1 which is annoying.
anyone aware of a solution ?
thanks
Hi Danny,
Welcome to the Sony Community.
Have you tried to Bravia Sync feature on your TV? You can see more details on how to set this up here.
Let me know how you get on?
Best wishes,
Sean Mc
Hi. Thanks for the welcome.
Sky HD box doesnt support Bravia sync.
My question is more basic, why doesnt the TV ‘remember’ the input that was being used last when the TV was switched off instead of defaulting to digital input when switched on ?
Thanks
Hi @Danny0367
You should ensure that HDMI Control is turned On on the Sky HD Box and On for the TV HDMI input you are using. That way switching on the Sky HD Box should turn on the TV and set it to the correct input. If that doesn’t work then you should speak to Sony Support as it should work!
Hi Danny0367,
I agree with SonyUser30Yrs. Try switching on the BRAVIA sync settings and let us know if this resolves it.
Vanilla_
Hi Danny0367,
You can try using a different HDMI cable and search for any devices detected for HDMI control. Let us know if this makes any difference.
Vanilla_
Thsnks for all replies
unfortunatley still not resolved.
TV is still always on digital input selection when first switched on.
@Danny0367 wrote:
When i select bravia sync on tv it says no devices found
Hi @Danny0367. Yes, but you turned on HDMI control on the Sky box? Turning on the Sky box should turn on the TV for you.
