KDL-32EX403U - usb video file formats
profile.country.en_GB.title
boydell2008
Hello All,
I am a new member due to the fact I have just bought the above model.
Can anyone tell me if there is a definitive list of video formats that I can expect to work via my USB memory stick?
Like several other members I have tried various files, but it all seems a bit hit and miss to me!
kind regards,
boydell2008.
5 REPLIES 5
profile.country.ro_RO.title
cri123
AVCHD, AVC, MPEG4 (M4V), DivX (AVI).
H264/MKV is not supported unfortunately, although it would be a simple firmware update for Sony....
boydell2008
Many thanks for that cri123... much appreciated.
regards,
boydell2008.
Message was edited by: boydell2008
profile.country.hr_HR.title
DamacizSi
Pls. find attached tabel of supported fail formats with extensions for Bravia models
Regards
Damir
robpetcro
The only way I could get my external hard drive to access it was by formatting it to FAT32, also make sure that if it is a partition, that it is an end one, I couldn't access mine when it was in the middle! Good luck, robpetcro
BlueSmoke1000
I've got divx, avi and Mpeg to play successfully, though some need remuxing into .m2ts format first.
If your Sony tries to play the file, but reports "playback not available", or you want to see if you can get it to play a file that it won't display at all, have a look at this thread :
https://www.sony.co.uk/discussions/message/638254
where I've explained how I got it to work using some freeware software.
This isn't the same as converting from one format to another (ie MPG > MP4), which would lose some quality in the conversion.  This remuxes the file into a different conatiner, the video and audio remains the same, but the Sony Bravia is a lot happier playing it :slight_smile:
Hope this helps.
