Hi All,
This is my first post on the forum, sorry it's a bit of a gripe
When using the functionality to sort out the Digital Stations, why oh why does it swap 1 station into another stations place. I.E. you want to move number 30 to number 1 and it swaps them instead of just inserting it and moving the other stations down. This would make it much easier to sort what programmes you want.
Also how about being able to move more than 1 programme at a time as well. Even basic digital boxes allow you to do this.
Does anyone else think this is annoying ?
Any chance of an update for the TV Mr Sony?
Hi FlyingKarpet
Thanks for taking the time to raise your concerns, much appreciated!
I obviously cant promise anything at this point but if it helps I kind of agree, it is a little annoying.
Be assured it will be passed onto the Bravia team who, in my experience, have always reacted very well to any and all feedback like this.
Thanks
Lee
I'd certainly agree with the first comment - it's an absolute nightmare! I've a KDL-40NX703, and trying to get them into any reasonable order is an absolute nightmare.
As a reasonable requirement it should do the following:
1. Allow selection of multiple channels to move
2. Insert them into the new position, moving the existing channels down
3. Not display the channel that you are moving.
Currently, if you try to sort them, the following occurs:
1. Only one channel can be selected at a time
2. The channel selected tunes in
3. Once the channel is moved, it swaps positions with the channel it replaces. So for example, if you move "More 4" to where "Five" is stored, it swaps "Five" to the bottom of the programme list.
You essentially have to build up a list of channels you don't want in between existing channels and then swap them out. It's a logistical nightmare.
I'm on my third attempt at this, and it's getting on to nearly an hour of my time to sort these. It should only take five or ten minutes at the most.
Please provide an update as soon as possible to an otherwise excellent interface!
+1
this would be great!
yesterday I bought a KDL-32EX715. Sorting of programs is a nightmare. My 'main-TV' is a samsung and I can download the programs on a stick - editing/sorting with a software on my pc and uploading it to the tv.
I am thinking about bring back this TV.
