i have a usb stick and i see some converted movies in avi format, some movies of them play and some they don't. i must put codecs to tv????
Find attached tabel of supported formats with extension via usb on Bravia and there You can see that .avi is good in Divx over usb but complated with Divx Home Theatre 3.0
http://www.divx.com/en/partner/certified/ic
Regards
Damac
Regards
Damac
