- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
I have just purchased a new Sony KDL-46W905A today. I cannot get the Netflix app to connect. I click on app and it gives me error NW4-8. I have been in contact with Netflix and they can't even sort it. Internet is fine - just can't connect to Netflix servers. Has anyone any ideas it's driving me nuts
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Well finally I see I am not alone with the Netflix problem on my kdlw905. After being given the run around by Sony, Netflix and my ISP all blaming each other it would appear that the issue is with Sony. I was advised to use the wired network, then to use wireless. I would have better results with a piece of string as neither of these worked. Being advised that I have the ability to stream Netflix from my XBOX or PC really isn't helping the issue. The app / tv has a problem. The tv was bought with these features proudly displayed as a selling point. If I wanted to stream just from my other tech then I would have bought a less SMART tv - oh I appear to have done that anyway!
The idea was to lose the SKY leach and move to a cheaper substitute - as with bw444976 I joined Netflix at the same time and have a wasted month of subs.
However, on a positive - the tv overall is brilliant. Just sort yourselves out Sony!!!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
under the warranty as you say a feature not working. Pity really otherwise
a top piece of kit
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Does anybody at sony look at these forums, still no resolution - as anyone solved this?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi there
Sony do look/read these forums, however it is primarily a community based forum, therefore if you want a direct response from Sony, you need to contact them directly : HERE
Saying that, last week I requested an update from Sony in regards to this issue and are now awaiting a response of which I will feed it back to you guys/gals
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi bw444976
This is actually a User based forum / community for Sony owners. (And fans)
Its also a place where users may be able to get some help too from other members if they are encountering any problems with their devices.
I'm sure Sony are aware of this problem. All I can suggest is to sit tight until there are anyinformation updates.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I have also now raised a support ticket
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi, I'm having the exact same issue on my KDL-46W905 bought 3 weeks ago. Running the latest firmware on the TV, using VirginMedia in the UK (tested also on Vodafone mobile internet). All other devices (Android, PS4, TiVo) can access Netflix without any issues. I have not been able to log into Netflix on the TV since purchasing it.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Same here - brand new Sony KDL46w905A out of box. Software update applied. I can use other apps on tv and can access netflix from other devices in the house, but not from new tv 😞
Same symptoms as everyone else, cannot access netflix servers.
Using virgin media internet access.
Very disappointed - easy netflix access straight from the tv (rather than PC) was one of the reasons I bought this. Needs a fix.
