Hello. I have a TV Sony Bravia model KDL-40EX720 bought back in 2012. Today was my first day using NETFLIX. I tried to watch a movie but I encountered the following problem. I connect to my account and choose what I wish to see. When I click on it and wait for the movie to load, the screen turns black and nothing is on. Since there's no trouble with the internet coonection, may it be a fault of the TV since it's old?
Any ideas?
Hi @marlo1968
What speed connection do you have?
Are you able to return to the movie / TV selection screen
when the screen turns black?
Have you tried restarting your TV?
(Unplug the power for at least a minute.)
You could also try signing out and then signing back into Netflix to see if that helps.
Hello.
The speed connection is above 5mbps, sometimes it reaches 6,5.
Yes, I can go back the tv or the site when I press the right button. I've tried it a couple of times. I even switched off the router, the tv but with no success. I'll go and buy a cable to connect the TV to the router. Now it's through WiFi.
I'll go through all the steps again and see what happens.
Thanks for your advice.
Hi again
You're welcome
Let us know how it goes.
Can you stream YouTube videos without any problems?
