I wonder if anyone here had any experiences of wall mounting the Sony KDL 50W829B TV - looks like it's not VESA compliant so would need maybe some adapters (if tats possible) to make it compliant before I can use a standard wall mount? I was hoping to get a full swivel mount so I can move it around. Maybe this one https://www.theplasmacentre.com/wall-brackets/tv-wall-brackets/sma04-443.html?cpgn=201&utm_source=pr...
Hi, I think your model might be the 50W82xB that's listed here under BRAVIA 2014 models, but you probably want to double check that with Support just to be sure.
