- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Preferred Pixel Format on GPU when TV connected to desktop and TV picture settings?
My question is about what's your preferred settings when you've plugged a desktop into the TV?
I stream movies and I play via the TV using my plugged in desktop computer games and also console games.
My TV is a Sony BRAVIA KD-75XE8596BAE.
TV-settings:
Currently I've Picture > Picture mode > Game (Cinema pro when I'm not playing) enabled and Light Sensor off and that's pretty much all and the rest is set as default.
My computer GPU settings:
Currently I'm using these settings, you can choose via the [GPU] control panel > Display > Change resolution
* Update frequency is set on 50Hz
I didn't go with the standard GPU settings on the pixel format, I did pick:
* Desktop colour depth: Highest (32-bit)
* Output colour depth: 8 bpc
- Other available options: 12 bpc
* Output colour format: YCbCr444
RGB and YCbCr422
* Output dynamic range: Limited
- Other options are 'FULL' if RGB enabled at Output colour format.
Why I'm asking this is because I noticed a huge difference in picture quality when I had my SONY BRAVIA KDL-46R473A I used YCbCr 4:4:4 on my former GPU, but didn't change anything else on the TV itself.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi TV_PC-Gamer,
I'll see if I can find this out for you. Maybe someone else in the community can help in the meantime.
Thanks,
Pascale
