Question about screen display
profile.country.en_GB.title
wltrspatr
A display keeps coming up on my Bravia screen giving my model type followed by a series of what is available on my tv eg. pc input,usb play,bass booster,usb play,freeview.
Could my set be in Shop mode do you think?
Message was edited by: wltrspatr
etritd
yes, I think your TV set is in a Shop mode and to exit that you have to do a factory reset. then an initial setting wizard will start asking you to select shop or home mode. bare in mind that with factory reset you will lose the present settings.
2 REPLIES 2
etritd
wltrspatr
many thanks
