Resetting KDL-40w705C
profile.country.IE.title
marconiro2
Thanks BigBen See you Have The KDL 55  I Would Like To  ReStart SetUp From The Beginin  But Believe This Can Cause Some Settings To Drop Out. With All The Helpful Info Around This Should Be Straight Forward Like Setting Up Google zeta, I Have Not connected To The internet as Yet. Any Advice Appreciated.
Thanks.
George.
2 REPLIES 2
Anonymous
Not applicable
Hi there
Am I assuming that you want to factory reset your tv? If so, instructions are HERE
marconiro2
Hi Quinnicus
Thanks  For  The  Info. Might Do The Easy Reset And Not The Factory Reset. Will Let You Know Later.
Regards.
