subtitles for movies on USB
profile.country.ro_RO.title
Copacu
hello, i have an Bravia KDL-32EX600 and i can't see 'avi' movies with subtitle. i have the movie and the subtitle in the same folder and with the same name. i have str or sub extension for the subtitle and it doesen't work.
can anyone tell me how to see the movies with subtitle?
profile.country.sl_SI.title
hribovec
create a folder on USB, copy "avi" movie (only one) and "str" or "sub" subtitles with the same name. A folder inside another folder is not allowed. On the remote control turn on subtitles with the button with 4 points inside screen frame. I have KDL-32EX500 and use "str" subtitles and it works.
Best regards
4 REPLIES 4
profile.country.en_GB.title
seboyad
I don't think separate subtitles are supported.  You would need to rip the movie with the subs burnt onto the image (dont ask me how :-)).
I'd be interested if anyone else has a solution?
Thanks.
hribovec
Best regards
profile.country.es_ES.title
kogjen
I have a KDL-40EX710 and I can confirm that it works as you suggested.
However the subtitles have a really strange font and are extremely difficult to read. I tried to change the font in Options but they are all 4 very similar and it didn't help at all.
Does it happen the same to you too?
Bye
El mensaje fue editado por: kogjen
hribovec
It is useful only font 1, because it has letters like slovenian. The subtitles are really a little strange, but I can read them.
Bye,
Vladimir
