Trouble setting up IP addresses on Internet TV
profile.country.en_GB.title
ripearc
I am having trouble setting up my TV to use the Sony Dongle. When going through the set-up process it has failed to pick up the correct addresses from my BT Home Hub 2 (I have reset the hub and TV to default settings several times following advice from the Sony support line) - so I was then advised to try manually entering the IP addresses. However when trying to move to the next stage in the process I get a message stating "Invalid entry - please check the IP address or Default Gateway entry" and I can't move on. I have checked the entries several times and all is correct.
The TV works perfectly via ethernet but I won't be popular leaving a cable down the stairs and across the lounge!
Can anyone advise?
0 REPLIES 0
