Unable to change channel
muffin1947
I am getting channel 28 for two of my TV stations which should be on channel 41 and seem unable to change them.I do change them but they then go back to channel 28 again.Here's what I am doing.selecting settings then digital set-up then digital manual tuning I then click on the channel number which is 28 and click the top arrow untill it gets to channel 41 this is where the problem starts what do I do then as if I go back to the tv screen it has gone back to channel 28 again.Can someone please help.My set is a  Sony  KDL-42W653A.i just want channel 41 instead of chanel 28.Thank's
1 REPLY 1
Anonymous
Not applicable
Hi there
Are you still experiencing this issue?  If so, have you tried a manual tune to set the channels correctly?
