Trying to register my TV to activate my guarantee, have set up a Sony account as required but when asked if bought in store or online I can’t make a choice. Any suggestions?
Hi Bertanne, I take it you mean you are unable to fill out the form due to some kind of technical error which doesn't give you the option to enter your selection, right? In that case it's best to get in touch with Support to inform them about it. You can use this contact form. Arthur
