What do the different letters in product type mean?
profile.country.en_IE.title
gosoothi
I'm totally confused - the models have ex , hx etc and nowhere tells me what they mean . I take it the higher the number the more recent the issue re 703, 803, 903 etc. Somewhere i read the u at the end means its a UK machine.
I have no interest in 3D , Prefer 200Hz and wifi compatible and just would like advice on whats the best in range at reasonable price circa the 703 range.
Message was edited by: gosoothi
profile.country.en_GB.title
Catmambo
Contributor
If you checkout - http://www.sony.co.uk/compare/tv-projector/ you can compare all the models and spec what features you want or don;t want..
1 REPLY 1
Catmambo
Contributor
