You Tube- internet browser will close due to an internal error
craig1912
Keep on getting this error message
Also BBC iplayer times out when selecting play.
Can get other internet content like BBC news etc.
Any suggestions? thanks
42 REPLIES 42
Anonymous
Not applicable
Brilliant - glad its working again.  You;re Welcome and have fun :slight_smile:
Amaryn
Can you tell me how to do this? I am having the same exact problem.
outrage_uk
For anyone with this issue, it appears that Sony/Opera are forcing you to allow ad.doubleclick connections. Usually if you have a gateway level ad blocking enabled (Diversion etc), connections to these sites will intensionally be routed to a localhost. Very annoying and not acceptable in my opinion. However, it can easily be resolved, by manually setting your DNS servers on your TV (in Network Settings, Custom Connection, Manual IP address) to Google's DNS  8.8.8.8 / 8.8.4.4 servers for example, rather than your own gateway. This will allow ad.doubleclick connections and not create the YouTube app to overlay the error. Hope this helps.
