Award Bios vs. AGP 8x
r.piras
Besucher
hi there
i own a vaio rx402,.. pushed with 1 gig ram and a mx4200!
now a have run 3dmark2001 to check the real performance of my system and what must i see... the agp rate is set to 1x!
because on my boar there is "only" an award bios rev. 1.xx i haven't the possibility to switch the agp rate to 4x!
what should i do? it's definitely borring me :slight_frown:
the motherboard is an "nowhere to find" ASUS A7N266VX and i dont know how (if it is possible) to upgrade my bios version!
thanx a lot for your help!
2 ANTWORTEN 2
profile.country.en_GB.title
kee-lo_
Mitglied
Try :arrow: this German forum to see if anyone can help you out. Sounds like a nice system too :slight_smile:
Or you could try :arrow: this AMD forum I used to frequent in :tongue:
chuckalicious
Besucher
Do a search for something called the GeForce Tweaker on Google or such like. It is a tool that lets you tweak almost every setting of your card. I have used it and can now set the AGP rate
