I have problems in using PMB in Windows 10. Can i use other software for the Sony movie file?Does Sony have software for Windows 10 for my type of camera?
Hello @Doina55,
you can use a cornucopia of different video editing programs for videos recorded with your camera.
PMB was replaced by PlayMemories Home from Sony.
I personally suggest to use Magix Movie Edit Pro, but it costs 60 pounds (or a similar amount of Euros in Romania).
Alternatively you can use Davinci Resolve, which is free.
- Nic
Hello @Doina55,
- Nic
I resolved my problems.
Thank you very much!
With friendship,
Doina
