Can a Windows recovery disk be made for NR32L/S
Vivek.Viku
Hi
I have recently bought a NR32L/S . I was wondering that is it possible to create a windows Vista recovery and back-up CD for this system. I was going through the online suport page for my system, it does not talk about the functionality anywhere wereas the inbuit tool always says check the online web support before creating or using a recovry.
Please can anybody tell me if its possible to create a recovery disk for this model
1 REPLY 1
Thalamus.
Champion
Hi Vivek.Viku,
welcome to Club VAIO.. :slight_smile:
if you haven't do so already download and install the VAIO Recovery Center 1.3.5.200806300 update, use the following link to download: VAIO Recovery Center 1.3.5.200806300
Then click Start, All Programs, then Vaio Recovery Center..
Click Continue on the User Account Control window
Select Create Recovery Disc then press Start.. :slight_smile:
