Dual Monitors
palmpalm
Посетитель
Dual Monitors
I have a RX-671 with AGP nvidia GeForce 2Ti 64mb card for the 15" LCD monitor that came with the PC. I would like to set up the PC for a second LCD monitor (video editing) and would like to know how to do it. Can I leave the AGP card in and buy a PCI graphics card (which one?) and connect the second monitor to the new PCI card? Or do I have to replace the AGP card with another AGP card that has 2 monitor outputs and if so what one would work?
8 ОТВЕТ 8
profile.country.en_GB.title
kee-lo_
Участник
Check if the GFX card you have has dual monitor support - if it doesn't, I'd go for a new card.
palmpalm
Посетитель
The RX671 card has one connection for the LCD that came with the PC.
kee-lo_
Участник
You'll need a graphics card that supoorts dual monitors.
VAIOneer
Посетитель
You can use a seperate PCI card, but it is a bit more of a hassle.
palmpalm
Посетитель
Are you saying that I would leave the factory installed AGP card in with the first monitor conected to it and then buy a second card (PCI) and connect the second monitor to it? Will the system recognize that and do I have to do anything special to set up the split screen. I would like to do video editing with software that supports dual screens. Thanks for your help.
kee-lo_
Участник
Yes, thats what Jaan is saying, but as stated, its difficult. I would get a card that can handle the 2 monitors, and get something with a lot of ram on it, > 32MB should be prefect for the application you want.
VAIOneer
Посетитель
Also depends on your budget :tongue:
kee-lo_
Участник
Yes, its not cheap, 2nd monitor + a dual card can be expensive.
