- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Is my DW-U12A DVD Burner a DRU-500A in disguise?
Hi
I have a RS226 with a DW-U12A DVD burner installed. The firmware is 2.0c
I have seen somewhere that this is the same drive as a DRU-500A. If so, will the firmware update (2.0f) work on my machine.
I'm having trouble getting my DVD-R's to work on my Philips DVD player (VCD's don't work as well).
What are the ramifications of installing this firmware if its not the right one?
Any help appreciated.
Steven
PS thanks to all who helped on my cooling fan question!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Yes the 12A is the OEM version of the 500A. The risk with updating the firmware (even if it is the correct one) is that you may end up with a drive which no longer works.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks
Has anyone upgraded the firmware on the U12A succesfully?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Only to what the 12A firmware allows which i did today but gotta test it out now , see how it does :smileygrin:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
What do you mean by
Please let me know how you got on, did you have any problems that you wanted it to fix?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I upgraded my U10A and it worked OK.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Rob, would you say its an acceptable risk updating the firmware?
PS I'm a fellow North Easterner - Gateshead
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
If you go to the download site for your vaio ( vaio link or summat) it will give you the firmware download for you on there, i would not bother messing with other firmwares , but the decision is yours.
I think the latest one for the 12A is 2.0E. The firmware gives you the reason you need it with the download , i never had any trouble but decided to upgrade anyhow.
Dan.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
It depends on how bad your problems are. I am afraid only you can make that decision.
I've updated the firmware a couple of times on my drive and haven't had a problem. Make sure that you follow the instructions carefully if you decide to do it.
Apparently the latest firmware for the U12A is pretty good.
