Hello,
I have got Sony VAIO PCG-81313M. I went to BIOS settings, set password blank. I have tought my computer will be restarted with no password. But it asked me BIOS password. What should i do? I tried unplugging CMOS battery but it did not work. Is there a jumper?
Please help me,
Fatih
I solved it. Reply or connect me from instagram [edited by moderator to remove personal details]. I will help you.
