Where can I buy/obtain recovery media for my Sony VAIO SVE1511D4E?
Hi bpountney,
Welcome to our community!
You can buy them - along with any other original accessories or spare parts- from Sony's authorised dealer EET Euro parts.
I'd recommend getting in contact with them and check the availability of the recovery discs using the serial number of your VAIO just to make sure you're getting the correct ones.
If this answered your question kindly mark it as a solution so other members can find it easily.
Cheers,
Batee5
Hi @bpountney
Your VAIO may have an inbuilt recovery partition; let me ask about and check out recovery CD availability for you too.
Mick
Hi bpountney,
Cheers,
Batee5
Hi @Mick_D
I had a recovery partition but I am trying to install to a new HDD since I am refurbishing my PC.
Thanks,
Benjamin
Hi @batee5
Is there anywhere I can actually buy digital ISO files for recovery media?
Thanks,
Benjamin
Hi bpountney,
I don't think you can buy just the digital files. You can order the CDs from EET and have them delivered to you.
Batee5.
