(Sheepishly) I can't work out how to get the side panel off!
DanSmith
I can't remove the side panel from my sony PCV RX402 VAIO desktop.
I know it's a bit pathetic :smileyblush: but I was hoping someone could give me a hint!
TIA
Dan
2 REPLIES 2
profile.country.en_GB.title
robpaxton
Go to www.vaio-link.com and download your user manual - the info you need is on pages 70-78
"Locate the tab on the upper right side of the rear panel, pull it back until the side cover releases, lift the side cover away from the main unit"
Regards, Rob
DanSmith
Hadn't found the http://www.vaio-link.com/ site - just what was needed.
Cheers,
Dan
