XP Drivers VGN AR61ZU
ciprinel2006
Please help me to find XP drivers for my VGN AR61ZU. Vista sucks!!!!!!!
2 REPLIES 2
Blencogo
There is no XP Drivers or Utilities Package as Sony do not support XP on your model. Newer models run far better on Vista than on XP as some of the machine's functions will not work with XP.
Installing XP is no easy task but if you must, have a look at this thread by costasp -
http://club.vaio.sony.co.uk/clubvaio/GB/en/forum/viewthread?thread=41647
:slight_frown:
ciprinel2006
For example i've installed Fifa 2008 on my vaio and on vista it sucks it doesn't work even with the lowest configuration i can hardly play and the AR61ZU has a 2.4 ghz dual core processor and 4 gb of ram 512mb graphic hard, on this configuration it must worked with highest configuration! I have other vaio FZN 21M and with this configuration on Vista is the same thing i've succesfully instaled XP on this one and Fifa 2008 with best resolution and best quality it works perfect that's why i need XP. Vista sucks!
