pc companion problem
Tasmeet
Hi, can anyone help me why I can't update my Sony Xperia z tablet to 4.3 jb using pc companion and sony update service. I did reinstall both software and disable antivirus and firewall, but still have no solution.
Tasmeet
Tags (1)
5 REPLIES 5
Tasmeet
Tags (1)
Uliwooly
You have to be more specific on your issue
Tasmeet
On the sony support, my latest available software is 4.3 jb. So I install pc companion and it shows my tablet is up to date. I contact the sony center, what they told me is to install latest java, but still no solution
Uliwooly
You forgot to read one part of the website
http://www.sonymobile.com/global-en/software/tablets/xperia-tablet-z/
Latest available software
You may already have the latest software, depending on the date of purchase. Software updates are released at different times depending on operator and/or country. Therefore, we cannot give you an exact date for when a specific update will be available for your device.
Android version: Google Android 4.3 (Jelly Bean)
Latest available software: 10.4.B.0.569
Release started: 2013-12-23
Tasmeet
Ya maybe I miss to read that, by the way thanks for your help.
