screenshot no longer available
RonP2014
FOLLOWING. Latest Sony update the screenshot function has disappeard
I tried reset hoping to return to origin is environment -- NO CAN DO --
Tags (1)
MikeViller
just for the record this is from 4.3 screenshoot
17 REPLIES 17
Uliwooly
Press and hold power & volume down at the same time
RonP2014
Yes, that worked until latest Sony update. That option has disappeard and I would like to know why.
Uliwooly
That seems odd, restart your tablet and try again
RonP2014
MANY times. But no change.
woody1983
You can do screenshot using the small app, clip manager, if u press the bottom right button u will see it it there, the app picture looks like a twin peak mountain in side a cropped frame
RonP2014
Thanks Woody, but I don't have this app.on my Xperiaz tablet
Before the Sony update simply long press on the power button brought up the option.
Not any more!!!
woody1983
Ihave it on mine, strange that its not on yours
RonP2014
FOUND IT, Woody. Thank you. Far less user friendly.
Still need schooling on making this method work.
Like saving image to local folder.
Still-- THANK YOU.
MikeViller
