screenshot no longer available
RonP2014
FOLLOWING. Latest Sony update the screenshot function has disappeard
I tried reset hoping to return to origin is environment -- NO CAN DO --
Tags (1)
17 REPLIES 17
moustaches2000
It works fine for me !
Legato
Screenshot's resolution isn't 1:1 to display.
SuhyL
It will work only with the app...
endee777
I cannot take the screenshot since the upgrade!..it is so annoying.I do  see the clip manager someone mentioned but cannot take any screen shots. I only am able to access the clip manager by going to the notes app. Can someone please help me!
profile.country.RO.title
_alexdon_
Power button+vol down at the same time should still work.
alexdon
endee777
That used to work UNTIL the awful 4.3 upgrade......Can anyone help???
endee777
Hi, turned it back on and presto, your suggestion worked!!  thanks so much
_alexdon_
You are welcome.
alexdon
