XTZ SGP351 LTE APN for AT&T
ScooterG
Does anyone have a known working apn setting for the sgp351 on AT&T? The default isn't working and the apn I had in my Nexus 7 3G tablet is not working either...I'm using the same SIM in both.
Thanks for any help before I broach the subject with AT&T Slightly_smiling_Face
ScooterG
Went to AT&T and they said the SIM just wouldn't work in a tablet period. I didn't mention it working in the Nexus. They couldn't figure out how to do a pre paid account in something that wasn't and iPad so I ended up at T-Mobile and a 3.5gb plan that gets 25MBPS down and 10 up.
18 REPLIES 18
Uliwooly
1st LTE must be enabled with your AT&T account, to do so, you need an LTE phone AT&T branded, so they can input the IMEI number in your account, thus enabling 4G LTE, there isn't a way around it
2nd
APN phone
MMSC: http://mmsc.mobile.att.net
MMS proxy: proxy.mobile.att.net
MMS port: 80
MCC: 310
MNC: 410
Authentication type: None
Bearer: Unspecified
H and H+ should work
Don't forget to give Kudos
ScooterG
Still a no go but kudos for trying. The SIM came from a AT&T LTE Sierra Wireless Data stick. Not sure why it works in the Nexus 7 and not the Xperia. Guess I'll have to pay up for some pre paid service.
Thanks again!
Uliwooly
Simple because the LTE on that particular Tablet its not compatible with AT&T's
Uliwooly
Here is the info
SGP351
UMTS HSPA+ 850 (Band V), 900 (Band VIII), 1700 (Band IV), 1900 (Band II), 2100 (Band I) MHz
GSM GPRS/EDGE 850, 900, 1800, 1900 MHz
LTE Band IV
http://www.sonymobile.com/global-en/products/tablets/xperia-tablet-z/specifications/
Don't forget to give Kudos (Click on the half star + )
ScooterG
The sim isn't from the tablet. Thanks again!
ScooterG
Yep. LTE 4 works fine on the data stick. HSPA+ works fine in the Nexus7.
Uliwooly
AT&T's LTE frequencies
700 MHz Class 17, 1700/2100 MHz
ScooterG
Would 3G work?
Uliwooly
3G and H+ should work
