How do I clean my new flat tv it holds loads of dust I have been told not to use usual cleaners
Message was edited by: cuboard
OMW now the whole contry think I am dirty or it maybe when I sweep my posh wooen floors the dust goes upwards but I think the mico duster may just be the answer
thanks
I find the TV attracts loads of dust, so I get the worst off with a duster, and then attach the "upholstry brush" attachement to the vacuum cleaner and gently use that to clear the rest.
thanks but i find a duster does no good and i do not have a hoover as i have all wooden floors
thanks 4 your reply
I find the microfibre dusters better than the regular yellow cotton ones.
(Maybe the lack of a hoover in your household explains the dust problem? :smileymischief:)
I will suggest you ecomist microfibre towel which i am currently using for my LCD screen to get rid of all the marks on my tv. It is hypoallergic and good for kids so you can use it without any worry. So personally i will suggest you this only.
