Front Facing Camera is Garbage
GELÖST
Andeekin
Besucher
My front facing camera on my Sony Xperia XA Ultra looks worse than the 8MP front facing camera on my Huawei G7. The main camera is gorgeous, don't get me wrong. But the front camera absolutely refuses to focus, and every single image comes out blurry, even with a still hand and at 16MP. I've tried every single setting, tried fixing the white balance, tried it on manual and superior auto mode and it just doesn't work. I bought this phone because the camera specs were beautiful, but I'm disappointed. Anyone else having problems?
Tags (1)
1 AKZEPTIERTE LÖSUNG
Akzeptierte Lösungen
Andeekin
Besucher
I ended up exchanging my phone for a new one (the exact same phone) because it was a problem with my device and not with how I was using it. The front facing camera on the first one I had was unable to focus, and my new one does focus. So the problem has been solved.
7 ANTWORTEN 7
Uliwooly
Does your phone has a protective case or film or glass?
victor91r
Besucher
HI. Turn off "soft skin" effect. My frontcam get great photos.
Focussing is normally, but if not, u may tap on your face on display
Andeekin
Besucher
I don't have a protective case, or film or glass. And as I mentioned before, I've tried every setting, including the soft skin effect.
1adrian1
Vielschreiber
The front camera takes great pictures as does the rear camera.
Roadrunny76
Enthusiast
Man, you amaze me with your excellent phone (battery, speaker, camera etc) . We are happy for you, we are not happy for ourselves. By the way, what was your previous phone that you are enchanted with your XA?
Uliwooly
@Aidylucas @Roadrunny76
Contact your Local support to get your device inspected.
Andeekin
Besucher
