Partagez votre expérience!
Can someone tell me which is the best portable charger for Xperia XA?
Thanks
Résolu ! Accéder à la solution.
portable charger or power bank? if the later then I use a
Sony CP-F10L Portable Power Supply
with multiple Xperias
Ok. Thanks for Your answer and advice! 😉
Just another question:
Portabble supply 8000Mah from Qlive 864715 with this specifications 8000mAh, Entry 5V-1A, out USB1 5V/1A, USB2 5V/2.1A, Acessórios: cabo micro USB/USB 20 cm, dimensões: A150*L77.8*P10 mm, peso: 169 g.
Do You think this is good for Xperia Xa?
Here in Portugal I don't find the other from sony.
Ok. Thanks again
