Is there any way to feed data to third party apps like MyFitnessPal or Withings HealthMate? Is there plans to support Google Fit?
As far as I know, it's not possible to share the data to a third party app. And unfortunately, I do not have any info if it will be possible in the future.
are there any new updates on this topic? Maybe Google fit integration or Myfittnesspal?
