4g not supported
Mk20
4g not supported
LTE not supported means 4g not supported pls needful
Mk20
2 REPLIES 2
Uliwooly
@Mk20
which device do you have?
settings > about phone
which carrier network and from which country?
if your SIM card it's older than a year, it'll be wise replacing it, and make sure that the phone's 4G LTE bands are compatible with your carrier network.
On a side note, some networks require to add the IMEI number to their database
Jake-SonyXperia
Champion
You can find the bands by looking through the white papers. I have supplied a link below to help you find the correct one for your product.
Whitepapers
