Hi @J0J0,
1. No, not in the default system. You may be able to add something like this using a third party app or widget from places such as the Google Play Store.
2. This depends on the wireless network you are connecting to. The network is what pushes through the request to open the browser and it usually occurs with free wifi hotspots that require you to sign in. Some may push through the request to simply let you know that you are connected to their network. There is no way to disable this as it is not handled by the phone.
