Automatic features questions...
J0J0
1. Is there a shortcut to put the Z5 Premium on vibrate instead of using volume button?
2. Whenever my phone detect a hotspot the web browser automatically opens up to conec5 yo the internet...anyway to disable this feature?
2 REPLIES 2
CameronT
Champion
Hi @J0J0,
1. No, not in the default system. You may be able to add something like this using a third party app or widget from places such as the Google Play Store.
2. This depends on the wireless network you are connecting to. The network is what pushes through the request to open the browser and it usually occurs with free wifi hotspots that require you to sign in. Some may push through the request to simply let you know that you are connected to their network. There is no way to disable this as it is not handled by the phone.
YoGem
Leader
About number 2, if the Hotspot is not saved in your list, you may have an option in WiFi->Advanced->PassPoint - that may be the trigger to open a chrome page to sign in into the system, otherwise I don't see any reason why your phone should try to open a page on your default browser.
