battery drain
harixperia
battery drain
Battery drains without any use. Charged to 100%@night and its 70 next day morningScreenshot_2014-02-21-08-27-13.png
6 REPLIES 6
profile.country.RO.title
_alexdon_
Do you have battery savers,task killers?Remove any kind of apps like those.
alexdon
Devastator
The "Phone" process in battery settings have the largest usage?
If yes - then it is known issue with the data_dormancy wakelock (search the forum - there at least 3 other topics about this).
The phone restart should temporarily fix this issue.
Also - I do not see the image, you have attached.
harixperia
No nothing other tham stamina mode activated. I am having these problems even after factory resetting many times
harixperia
The phone app just used 5%
_alexdon_
Force shutdown(power button+vol up until the phone vibrates 3 times).After that,turn it on normally.
alexdon
Devastator
Well, it looks like it is something different this time.
